Beolab 9 | Beolab 8000 | Beolab 6000 | Beolab 2 | Beolab 3 | Beosound 9000 | Beoplay A9 | Beomaster 8000 | Beovox M75, / S75, / S45.2
Beosound has also DIN out so you can connect it to Beomaster via DIN-RCA cable
Hi Howzit,
Which speakers are you using and which product are they connected to please? Do you have other rooms connected to the 9000 by Masterlink, or a TV in the same room please? Are both products in the same room (ie. within remote control range)?
This will help us to understand the best way to get everything connected, so that we can give you the best advice.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
