I'm a happy owner of a pair of Beolab 9 which I have connected to a 3rd party preamp using Steve's Cinch to Powerlink cables. However there is a constant light hum in the speakers independant of the source used or volume level in the pre amp. The hum stays present if I disconnect the cinch cable from the pre-amp, but it disappears when only the cinch ground is connected to the pre amp's signal ground. This makes me think that the hum is caused by improper earthing of speaker and because an ICE amp is balanced by design and with all other balanced amps the signal minus should be separated from the actual ground.
When using a B&O source the service manual of the B9 clearly states that MK3 powerlink must be used because of the extra data ground on pin 7.
Hi Eriperi,
Thanks for your purchase from my store, I am sorry to hear that you are having problems. There should not usually be any audible hum when using the Beolab 9 speakers with a good quality pre-amp, so this sounds as though the noise may have been induced into the wiring by nearby electrical equipment, or by an issue affecting the pre-amp.
Beolab 9 speakers have an unbalanced (single-ended) audio input, so they work best when used with the unbalanced output of a B&O system or pre-amp (in this case via RCA pre-out sockets). My cables are correctly wired for this purpose, with the extra grounding pin added (pin 7) for the case of the ICE Power amplifier in the speaker.
I will email you directly to confirm the model number of your pre-amp and to help you to resolve this issue for you.
Please feel free to get in touch if you have any questions in the meantime.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
