Hi All
I have just switched from a BT landline to Sky Talk and I am no longer able to make calls via the phonebook or return calls via caller ID without receiving the message that the number does not exist. I have managed to establish that if I press the call button then manually type the number it works but if I auto dial it doesn't unless I add a dummy digit at the front. I never had any issues with BT so can only believe the issue is a setting with Sky Talk.
Just wondered if anyone else had experienced this issue and resolved as Sky seem to be struggling with it. For reference I have a Beoline 2 with 3 x Beocom 6000 Mk Ii's and 4 x Beocom 2 Mk II's connected.
Many thanks
James
Excellent - I shall arrange a visit. Many thanks for the heads up.
Hi
I just wanted to update on my post even though it's been several years. I finally switched back to BT and everything is working fine so be aware if you switch to Sky!
