ROON ready endpoint for BL50
This post has 3 Replies | 0 Followers
Flere
Netherlands
Posts 345
Flere Posted: Mon, Jun 25 2018 10:36 PM
Any suggestions for a device which can acts as a ROON ready endpoint for the BL50 ?
And how this endpoint is then connected to the BL50 ?
- Flere
smile and enjoy the moment
Millemissen
Flensborg, Denmark
Posts 14,680
There are rather many devices with support for Roon nowadays:
https://roonlabs.com/partners.html
How about hurrying up to get yourself an OPPO 205:
http://archimago.blogspot.com/
As for how to hook it up to the BL50’s - I’d try the different options to see/hear, what is best.
Flere
Netherlands
Posts 345
Flere replied on Mon, Dec 3 2018 9:55 PM
I am now using a Bluesound Node 2 as ROON ready endpoint.
The BL50 master is connected via coax SPDIF to the BSN2 with fixed volume.
The BL50 volume is controlled via Essence remote and/or B&O app. Whenever the BL50 is started it will start with the set default volume.
Works all very well.
- Flere
Fl_ip
Posts 160
Fl_ip replied on Tue, Dec 4 2018 6:20 AM
Flere:
We use the Sonore microRendu in our shop connected with USB directly connected to the BeoLab 50 and also the BeoSound Core connected with Cat7 icm with ChromeCast Audio. Works perfect!
- Flere
Page 1 of 1 (4 items) | RSS
