Hi!Setup is:Mainroom:BS6500 with 1611BLC with Samsung TV and BeolabsLink rooms:Various Beoplay Multiroom productsBedroom:BV8Everything works as it should. I can control my Turntable with app and distribute to all rooms. I can distribute TuneIn/Deezer to Mainroom through BLC.Problem: I want to introduce my BV8 to the ML because i would like to use it as a linkroom speaker.Furthermore i have a Beolab 3500 i would like to use also.I can control the Beoplay products from the Bedroom on the BV8 with Beo4. But the sound is not distributed. If i choose a source on the BS the audio is on the BV8.BS: Option 0BLC: V.master Option 2BV8: Option 6How can i introduce the NL sources in my ML network? Do i have to reprogram the BLC to AV.Master?
