Hi!
I recently bought a Beogram 5000 - my long lasted search for a Bang & Olufsen turntable had finally ended. The turntable works fine, but. When the platter spins, it makes a rather funny noise; I don't know how to explain the sound as english isn't my first language, but it resembles whirring of some sort. I took the turntable back to the store and they checked it. They made the whirring go more quiet by lubricating the motor but I can still hear it even thou I would sit two meters away from the turntable.
So my question is, is this normal and if it's not, what can I do to get the whirring away. I know that a turntable shich is belt operated makes little sound, but it shouldn't be that loud that you hear it to your listening positiong, right?
All help is appreciated! Thank you!
I agree with what Peter suggests; Bad motor bearings or brushes.Try spinning the motor by hand (unpowered and without belt).
Hi I have a Beogram 3300 which sounds like the platter is catching the frame, works fine without platter
you mentioned height adjustment, how do you adjust that?
thanks
mike
