I have just got a alexa spot as the speakers in the spot not brilliant I understand how do I connect so I can play back music through my beolab18
malcolm welborn
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Thanks Hiort!
Hi Malcolm,
You can connect a pair of Beolab 18 speakers to the headphone socket of your Amazon Echo Spot using this cable:-
https://soundsheavenly.com/line-in-connection/minijack-to-beolab-line-in-using-phono-rca-sockets-one-cable-for-two-speakers
If you have a hifi or audio system in the room near the speakers, please let me know the details, as it may be better to connect the speakers via this instead of directly to the Echo Spot.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
many thanks for info away till the new year will deal with then
