Hi All,
I have a CD50 which up until last week was working fine. It has since developed a number of issues, none of which I can seem to figure out. I assume it was a lack of maintenance from the previous owner. I've only had it a month.
Every CD I have tried starts from the beginning of the 1st track every time, so I don't think it is the disk drive motor....
The issues are:
If anyone can shed any light on this that would be greatly appreciated. I assume it just needs some adjustments made to the radial bias and focus circuitry. But I don't have a test disk or easy access to a signal generator or oscilloscope. If need be I can probably get a hold of SG or Osc, but would rather not have to.Cheers,Luke
So I've managed to get it working quite well.
But it still has issues when playing after the disk has finished. After pressing play the laser carriage starts to return home and before it gets all the way back, the disk ejects and the play button becomes unresponsive.The carriage gets nearly all the way back, literally within a few mm before the disk ejects.
Does anyone know what might be causing this? It's the only issue that's annoying me now as the others only happen on disks with more than 20 tracks, which I have very few.
iagreewithjosh:But it still has issues when playing after the disk has finished. After pressing play the laser carriage starts to return home and before it gets all the way back, the disk ejects and the play button becomes unresponsive.The carriage gets nearly all the way back, literally within a few mm before the disk ejects.
I have a vague feeling that this is normal (or at least common) and caused because many CDs are actually longer than the standard allows. The system times out before the carriage has reached the other edge.
I sold my CD50 years ago, but I seem to recall it did just that.
--mika
A Beogram CD50 is not just a Beogram CD50.There are so many differences, production changes, aftermarket modifications etc.Some machines had some modificaations, others have other, depending on which batch it was originally, which modificationswas made from factory, what owner(s) later complained about and what restorers like you found.Hardly two machines are completely identical by now.The first production batches of CD50 did exactly as you describe, after playing a fairly long CD.A modification will correct it - in some of them...In others it will have no effect.
It's not really a fault with the deck, - it's just one of its lovely quirks.
Thanks for your replies Mika and Martin. That is definitely an odd quirk.
Is there anyway to find if the modification would work on my CD50? And if so, what is required for the modification? I wouldn't mind trying it out if anyone knows how to do it.
Cheers,Luke
iagreewithjosh: Thanks for your replies Mika and Martin. That is definitely an odd quirk. Is there anyway to find if the modification would work on my CD50? And if so, what is required for the modification? I wouldn't mind trying it out if anyone knows how to do it. Cheers,Luke
I will have to look it up, but if I remember correctly, the modification is a matter of fitting a capacitor - depending on the production block number.The number is a one-digit hexadecimal number (0-F) and it is found, either stamped or handwritten, on the label at the right side of the internal vertical metal plate (divider).
Is this the correct label Martin?
https://imgur.com/gallery/ppxsk0H
Sorry for hosting it on Imgur. Had trouble uploading it here.
Exactly.That's a block 7.
So does that number tell you anything about whether this modification you mentioned above will work? Is it an early, mid or late production model?
Hi Martin,Just wondering if you would be able to shed some light on how to remedy the tray opening before the laser carriage returns home.
