Hi all, I have just bought a Chromecast which is to be used on my Beovision 8 32 in the kitchen. My idea was to use the Chromecast through the HDMI and power it via the USB service port (if it outputs enough amps for the Chromecast). I found a diagram online for the 8 40, its states the port is under a flap which is the second groove in from the right, I can not see this on the 32, Does anyone know if there is a USB port on the 32 ?
Thanks for the reply Pat the TV is still on the wall and I was trying to figure out where the hidden USB port was without removing it. Guess I'll have to power the Chromecast independently.
