Were the white product cabinets painted or are they covered with a plastic veneer? I have a turntable that has a plastic veneer and I am wondering if it is factory or a remodel by a previous owner?
The white surfaces is apprx. 0.5mm thick white laminate, glued to the plastic base trim.
Martin,
Thanks for the confirmation. The Beogram 8002 has a corner missing. Any idea where I might get another piece?
i have read that you offered a cap kit for the Beomaster 8000 in the past. Do you still sell one?
Art
DIY stores can often supply iron-on or self-adhesive laminate strips meant for kitchen table edges etc.
Capacitor kits are still available.
Thanks.
Do you offer kits to rebuild the LED displays? What is there cost of the capacitor kit for a BM 8000?
Led rebuild, I can do it but there is no kit.
Cap kits, email me.
Are you still rebuilding Beomaster and Belford 8000 led panels? I have a set I would like to restore.
art
