Beolink 1000 Audio Terminal
This post has 1 Reply | 0 Followers
Beomatt
Posts 6
Beomatt Posted: Thu, Jan 24 2019 5:56 PM
just a quick help issue, can anyone clear up if the early Beolink 10000 audio terminal can work on a Beosystem 6500?  Do I need to press keys in a certain order?  Thanks in advance
trackbeo
Posts 644
trackbeo replied on Fri, Jan 25 2019 10:04 AM
Yes, a Beolink 1000 will drive a Beosystem 6500.  (Early or late, I don't believe it matters.)  There is no concept of "order" in key pressing: you press the source -- RADIO, TAPE, CD, PHONO -- to turn the Beomaster on. (Yes, there exceptions like SHIFT, then TAPE does TAPE.2.)  Obviously the volume controls and number keys only work *after* the system is on and playing, but this is order of operations, not multi-key-pressing.
Page 1 of 1 (2 items) | RSS
