Beogram 7000
This post has 10 Replies | 1 Follower
cnbarnes
Posts 12
cnbarnes Posted: Sun, Mar 3 2019 7:44 AM
hi
When I put 12inch record on my turntable it does not spin.
The centre does turn but the record is flat on the turn table and does not move.
To me it looks like the centre needs to lift the record of the table but it dont any help anyone ???
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Mar 3 2019 9:22 AM
Most likely because the subchassis has been set to low.
This allows a 12" record to rest on the alu surround rather than the platter.
The subchassis must be adjusted so the platter is apprx 1mm above the surorunding metal surface,
cnbarnes
Posts 12
Ok thanks
How do I fix that ??
cnbarnes
Posts 12
I just got the beogram700 after a 4 week wait got all my old Lp"s out set myself out for a night in listening to my old classics and problems as stated
L Spad
Brighton
Posts 271
Just to check - did you remember to loosen the 3 transport screws (assuming you locked them down for storage)
cnbarnes
Posts 12
cnbarnes replied on Sun, Mar 3 2019 10:12 AM
Pass I'm not sure it was locked in the first place.
It plays a 7inch ok just seems the 12in is to heavy so the black plastic and spindle are turning but 5he record stays put .
Dillen
Posts 13,191
Dillen replied on Sun, Mar 3 2019 10:30 AM
Get the user manual, it will tell you to set up the deck.
cnbarnes
Posts 12
cnbarnes replied on Sun, Mar 3 2019 11:13 AM
Sorry I did not come with one
Can you help 👍👍
cnbarnes
Posts 12
cnbarnes replied on Sun, Mar 3 2019 11:51 AM
All sorted ddeeeerrrrrrr travel screws🤘🤘🤘
cnbarnes
Posts 12
L Spad
Brighton
Posts 271
Glad it's working - enjoy your turntable!
Page 1 of 1 (11 items) | RSS
