Hi All,
New to forum, and still trying my best to navigate around site, so forgive me if the question has been asked before, but could someone tell me which remote control I need for my beosystem 3000?
Thank You
Welcome to Beoworld! The Beomaster 3300 amplifier (with matt grey panels on the top) can work with many different B&O remotes, the most popular ones to look for are Beolink 1000 and Beo4.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Steve at Sounds Heavenly: Hi, Welcome to Beoworld! The Beomaster 3000 amplifier (with matt grey panels on the top) can work with many different B&O remotes, the most popular ones to look for are Beolink 1000 and Beo4. Kind regards, Steve.
Hi
Beomaster 3000 would not work with Beo4/Beolink 1000, but only with terminal 3000. The first Beomaster that works with Beo4 is Beomaster 3300
Søren
Hi Søren,
Sorry about that, you are quite correct! I was thinking of Beomaster 3300......
Thanks guys for your help.
Lee.
