I own a B&O Beocenter 9300 and would like to use it on the Internet, mainly for YOUtube plays
Any advice on connecting it to the net apprecated
Beiber39:Hi, I own a B&O Beocenter 9300 and would like to use it on the Internet, mainly for YOUtube plays Any advice on connecting it to the net apprecated
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hi Beiber39,
This cable will allow you to connect the headphone socket of your TV or laptop (or an Apple Airport Express if you want a wireless connection) to the Aux or Tape 2 socket on the back of your B&O system to play YouTube sound to the B&O speakers:-
https://soundsheavenly.com/bang-olufsen/minijack-to-aux-in-ipod-to-beosound-beomaster-beocenter-using-aux-din-socket
Please set the laptop volume to maximum when connecting to the B&O system – this is normal when using a headphone output with a home audio system due to the low output levels produced by the laptop.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Hi Beiber39, 1.) best solution is cable connection from your youtube playing device. You can use the suggested cable from Steve and if there's nothing that fits your needs, he can produce any cable (and length) you need. 2.) if you're using multiple devices (e.g. Smartphone, tablet...) for youtube, you can add a Bluetooth receiver to your beautiful Beocenter 9300. It should support "Apt-X" codec for better sound quality. You'll need a Bluetooth receiver with an analog output as your Beocenter 9300 only have analog inputs.
