Beovision 7 type 9344 / Roku problems - loses picture after set up wizard is run
This post has 1 Reply | 0 Followers
Geoff3031
Posts 2
Geoff3031 Posted: Fri, Feb 8 2019 2:54 PM
Hi, I'm attempting to connect a Roku Express to a Beovision 7 type 9334 using an HDMI to DVI + Audio splitter. I followed the instructions for HDMI to DVI conversion on another thread and got the Roku set up wizard on screen, result!
However, after running the wizard the Roku downloaded new firmware and rebooted, then there was no picture. I assumed that this was due to the Roku outputting at 720p for the wizard and 1080p for normal use so I connected it to another TV, switched it to 720p and reconnected but still no picture.
Any ideas?
Thanks.
Adaptor https://www.amazon.co.uk/Coaxial-Converter-Adapter-Projector-Blu-Ray/dp/B0180V18KQ
Geoff3031
Posts 2
Geoff3031 replied on Sun, Feb 10 2019 5:39 PM
Update - looks like the problem was with the adaptor. I directly connected a DVD player set to 720p and got a picture so I think the adaptor was upscaling to 1080P. Also the product description on Amazon has been updated and it's now described as an auto-scaler (and the price has gone up by £15!).
Does anyone have a recommendation for a HDMI to DVI & Audio adaptor? I would prefer to have a digital coax audio output if poss.
Thanks.
Page 1 of 1 (2 items) | RSS
