Re: The 'Line Busy' problems with my Beocom 6000 system - ( see earlier posts ) - can I use a Beoline PSTN to replace the current base charger/PSTN table stand if this unit is found to be the cause of the problem?
Yes, but worth having a read of the FAQ to check the compatibility of the PSTN base that you buy.
See here: https://www.beoworld.org/faq_view.asp?id=74
And (having read your other thread) I would borrow a simple landline and check your connection before thinking about getting new B&O equipment. Either that or call your landline service provider and ask them to check the line.
