I own a pair of S60's that I purchased from a local gentleman. He said he and his son rewired the crossovers. I pulled the woofers out to take a look at the crossovers and noticed that all of the ferrite inductors are missing from the crossover coils. What do you recommend I do about this? The speakers sound fantastic, but I would prefer them to operate withing factory specs. Here is a photo:
http://i.imgur.com/39ZWXhc.jpg
Welcome to Beoworld !Missing the ferrite cores from the two outermost coils, but otherwise it looks quite original to me..I can't really see that any rewiring has been done either.
Also i want to ask what happens if the ferrite cores missing.
How they sound? Is it safe?
Can i replace the two coils with "Air" ones?
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
What if i change the specific coil on both speakers with the one below?
Any problems with it?
https://www.parts-express.com/dayton-audio-070mh-14-awg-perfect-layer-inductor-crossover-coil--257-314
