Beogram 1000 - arm spring question
This post has 7 Replies | 2 Followers
ameerun
Posts 2
ameerun Posted: Sat, Jul 29 2017 10:52 AM
Hi, I just purchased a Beogram 1000, working fine, but the arm doesn't lower enough onto the record. There's a spring hanging lose attached to a small blackring on the arm.
Anybody an idea where the other side of the spring should be attached? Maybe that will fix my issue...
Thanks,
Rob
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Jul 29 2017 2:05 PM
Hi Rob, and welcome to Beoworld!
Yes this will most likely solve your issue. Also keep in mind that arm height could be wrong.
This is a picture from the Internet.
Jacques
ameerun
Posts 2
ameerun replied on Sat, Jul 29 2017 8:53 PM
Thanks, it works! Thanks for the picture Chartz!
I hooked the Beogram up to a Beomaster 900, but the volume is very low, even if I turn that dial (screw) on the back of the Beomaster at maximum. Any idea what that could be or does it need an extra amplifier?
Thanks,
Rob
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Jul 29 2017 11:37 PM
That's because you don't have the RIAA module fitted. You may either fit a phono board in the BM or in the Beogram.
See Martin's pictures here:
http://archivedforum2.beoworld.org/forums/p/14071/123574.aspx
Jacques
Tim Ornellas
Hove, UK
Posts 25
Hello Chartz
I have just rebuilt a Beogram 1000 completely and am about to reassemble it. You mention the importance of the correct arm height. Is this a measurement and if so what is it please? Thanks for any help you can give me.
Kind regards
Tim
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Mar 23 2019 6:51 AM
40mm from deck surface to the top of the suspension "ring".
It's all in the servicemanual. As a silver member you can download manuals.
Seeing as you are rebuilding a deck, I'm sure you already have it.
The adjustment is important since it sets the needle tracking angle.
Tim Ornellas
Hove, UK
Posts 25
Thanks Martin
I just downloaded the service manual.
This is my first rebuild so I am pondering if I should strip down the motor to lubricate (infuse) the bearings. The turntable runs at the correct speed but takes 4 or 5 revolutions to get up to speed. Do I need any special tools to take the motor apart please?
Tim
Dillen
Posts 13,191
Dillen replied on Sat, Mar 23 2019 5:13 PM
About 4-5 revolutions is not uncommon to reach the correct speed.
But no doubt it would benefit from a thorough service.
Page 1 of 1 (8 items) | RSS
