Hello, my first post here from Down Under where it's as hot as hell, and envying all Northern Hemisphere members wherever you may be.
After a period of two years idleness, the tray on this Beocord 5500 will not eject. I suspect rather than know it will be a broken belt?
I have a user manual but would dearly like a PDF technical manual to assist me do some home repairs.
In any case, I assume it might simply be a handful screws to open the case and expose the belt/s. I have no known dealer here in Australia and would appreciate a push in the direction of belts and bits for these machines.
Any advice most welcomed. Thank you.
A full service manual is available on site for gold and silver members
Ron
Yes, but the servicemanual will not tell you how to replace the belts.I can supply belts and I can include detailed mounting instructions (photos and english text).
Dillen, you’re the man! 😀
Please advise how to order the belts from you, and your payment requirements also.
Very pleased to have found you!
Email or PM me.
