NEWBIE with PERSPECTIVE BEOVOX MC120.2 speakers - needs helps
dusktilldawn
Posts 5
dusktilldawn Posted: Sat, Mar 23 2019 11:55 AM
I bought a pair of used Beovox MC120.2 speakers for £30 not knowing what I was getting myself into... seemed like a good price - speakers 'look' amazing (but a bit tatty to be honest) - hooked them up and NO BASS?
So that's no bass from either loudspeaker - sound is coming out of the treble and mid-range, so what's going on here? Do I need to somehow get into the speakers and sort this out?
Picture:
Saint Beogrowler
Saint Paul
Posts 780
Do the woofes’ cones move in when pushed gently? Should move in with the slightest of pressure and then bounce back when released.
You got a fantastic deal and these would be worth the money it will take to get fully working.
dusktilldawn
Posts 5
They certainly look nice. I don't know if you are familiar with the insides or not but here are some photos after I removed the front panel...
So any help in diagnosing the fault would be appreciated:
Søren Mexico
Mexico City
Posts 6,411
If the Bass drivers pass the "push test", Change the electrolytic capacitors in the crossovers, check the other components, clean all connections for oxidation.
dusktilldawn
Posts 5
The drivers do pass the push test OK. I cleaned the connections to the bass driver using deoxit D5 - don't forget the treble and midrange units work. fine.
Saint Beogrowler
Saint Paul
Posts 780
As Soren says, I’d check C1 15uf, R1 6.8 if the service manual I have here is the same as what is installed. Once you get it working I’d want to replace all those capacitors anyway.
I’d start by testing the woofer for functionality. You can try by putting a 9v battery to it if you don’t have a meter. Lots of YouTube videos about testing drivers you should check out first.
dusktilldawn
Posts 5
I've put a meter across the terminals of the bass driver and not getting any reading - I guess that means open circuit and a shot bass unit.
Both speakers have the same problem.
Can the bass units be reconditioned - the magnet is etched with X820415
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Mar 24 2019 11:28 AM
Difficult repair.
Under the dustcap the thin copper leads that run from where they meet up with the flexwires to the voicecoil gets eaten away by the
glue used to secure the voicecoil former to the cone.
Careful drilling, heating and cutting into the glue, close up to the coil former will often uncover a tiny piece of lead that a fresh piece
of lead can be soldered onto.
Close to the wire I use a dedicated (cheap) soldering iron to melt away the glue without risking damage to the thin leads.
dusktilldawn
Posts 5
OK a better question perhaps - can I send the bass units off somewhere to get them professionally repaired? Seems a shame to replace them with another set of woofers that may never be as good as the originals.
Funny how both these speakers suffered the same problem.
Page 1 of 1 (9 items) | RSS
