I have a Beosystem 3 and DVD 2. They are in storage while I refurbish my main living room. The Beosystem 3 has a Freeview (DVB-T) tuner built in. Can I record from that built in tuner to the HDD of the DVD 2?
The Beosystem will be paired with my LG OLED TV and I'm hoping I can record a program from the built in tuner on the Beosystem while watching a different channel on the TV using the Freview Tuner in the TV.
Stoobie
leogoeswild:Can’t you put a usb I the tv and record to that?
Can I record a different channel to the one I'm watching by doing that? I thought there is only 1 tuner in the TV?
Duplicate post.
I would love to see a pic of your stacked BS3 and DVD2 system. I always thought that was a brilliant idea of B&O. However, in the U.S., our BS3 version does not have scart.
Hi Beojeff,
It will be a while before I get them set up. Here on the product pages is a picture of them stacked (one of the photos on DVD2 page shows It) I take it the lack of scart means you cannot control the DVD2 with a US Beosystem3?
https://www.beoworld.org/prod_details.asp?pid=1241
beojeff:I would love to see a pic of your stacked BS3 and DVD2 system. I always thought that was a brilliant idea of B&O. However, in the U.S., our BS3 version does not have scart.
The pics are from B & O
pic number 2
beojeff: I would love to see a pic of your stacked BS3 and DVD2 system. I always thought that was a brilliant idea of B&O. However, in the U.S., our BS3 version does not have scart.
Correct. It's been my understanding that the only means of control of the DVD2 is via scart.
That is my understanding for most of the later video recorders along with the DVD 1/2 and the HDD 1/2.
Rather than re- post I thought I'd revive this thread. Can anyone help with the question I originally posted? The replies went off on a bit of a tangent and I didn't really get an answer.
I'm not too fussed that the recorded picture quality will not be as good as watching directly on the TV but as I have the Beosystem 3 (mainly for my masterlink system) I am hoping that I can use it and my DVD2 for recording TV.
Many thanks.
Hi Stoobie,
it should work with the following restrictions:
- No B&O sound possible while Live TV, only TV speakers
- You have to 'force' the TV to use it's built-in tuner and display the live TV (switch with the TVs remote from HDMI input to Freeview)
- No 'live' recording (by pushing <RECORD> twice on the Beo4) except this complicate sequence: switch TV to HDMI in 8TVs remote, start B&O freeview (now get your Beo4), select the same channel as Live-TV, start recording, switch TV to freeview (again get TVs remote). And don't forget to stop the recording afterwards in the same complicate manner
So to summarize all: It should work but is not the B&O feeling. And you need to have the TV remote also in use.
Ralph-Marcus
Thanks Ralph-Marcus,
I am hoping to program my Beo6 to control my setup. I'll hopefully have it all connected within the next month or so, and then I can start programming my Beo6. I might be able to program some sort of macro to do all the steps you suggested.
Many thanks
Ah, ok you got a Beo6 this makes it a bit more comfortable. Atleast no second remote lying around :)
