getting the s-vhs connection to work on the MX4002 CRT
vipermk2
Posts 3
vipermk2 Posted: Mon, Jun 10 2019 10:34 PM
Hi all
I have been struggling to get the S-VHS connection to work on my MX4002 CRT. I am not sure the reason why its not working is because I am trying to connect a US imported Gamecube that uses S-Video rather then S-VHS?
So from my understanding and research, you have to select the S-VHS from the sockets menu. On the the S-VHS, the options you have are: Off and AV1. I put mines on AV1. Correct?
Now, the only options I have for the AV1 options are: Off, V.TP-1 B&O, V.TP-1, V.TP-1+Dec and DVD. Which ones should I been selecting? As I have tried all combinations but I cant get any picture or sound.
The audio split into a scart adaptor(It has a little switch on it to "Input") that has the red, white and yellow inputs. And the scart itself is in the AV1 socket.
The Gamecube and cables do work as I did using those cables on a scart spliter that uses half of those audio cables.
Any suggestions or advise would be gratefully appreciated.
Page 1 of 1 (1 items) | RSS
