I hope someone can help?
I have a BS3000 (the software was upgraded to support N-music). How do I add N-music and N-radio to the options? I have looked through the manuals and can not work it out (I have a beo4 but it does not have PC it is an older one that has the AV button!).
A second question is I have also upgrade my beomedia 1 with 1GB of memory and IE7, it is connected to the BS3000 by master link and to a LG TV via scart. I have been using a USB keyboard but can not work out how to stop n-music / radio or exit the web browers once they are running. Is there anything that details how to use the beomedia with a keyboard (have looked in the manuals and on this forum as well as doing a google search) ?
Hope someone can help.
Toby
Hi Ralf,
Thank you for the quick response.
Now need to figure out what I can actually do with the BM1
