BR1 bug ?
This post has 3 Replies | 0 Followers
Silou
Switzerland
Posts 465
Silou Posted: Thu, Oct 10 2019 7:43 AM
BR1 without BT:
Product list: "BEO4 AV". Remove all other.
Hide all sources except TV and DVD.
Press TV button and you will see… DTV and… TV, DVD
You can't to remove DTV!!!!
You can't move DTV's position on the list. Because with "Setting" "Move" you see only TV and DVD !!!
Worst each time you are pressing on TV button, remote send DTV. Because DTV is at the top.
Reseting remote don't change this behavior…
Bug or user mistake ?
thanks
Pat
Posts 152
Pat replied on Thu, Oct 10 2019 9:26 AM
In your case DTV is selected as a default. For TV sources and MUSIC sources you can select a default source - ticked. It is possible to change it in the menu.
Silou
Switzerland
Posts 465
Silou replied on Fri, Oct 11 2019 6:44 AM
Solved. DTV was selected as default. Thanks
Pat
Posts 152
Pat replied on Fri, Oct 11 2019 9:03 AM
Page 1 of 1 (4 items) | RSS
