Control of V1 using NL/ML converter over ir
badgersurf
Posts 539
badgersurf Posted: Thu, Apr 18 2019 7:18 PM
Hi all,
my V1 has developed a fault with it not responding to IR commands, it can be controlled via the app, so looking at old threads guess this is the same problem a lot of people have had which cost £700 to fix.
my question is if I connect a ML/NL converter with an ir would i be able to control the TVs through ir using my  Beo4? I do have a BLGW as well.
unfortuntly I can get to the set to try this at the moment.
hope someone has any idea?
Toby
beojeff
USA
Posts 2,012
beojeff replied on Thu, Apr 18 2019 10:34 PM
I don't believe that you can. I tried doing this with my BeoVision 10 -- since the IR receiver is so low on the BV10 that I wanted an IR receiver more accessible from my bed. It didn't work. However, you CAN send LIGHT/CONTROL commands.
badgersurf
Posts 539
Hi Jeff,
Thanks for getting back to me (thought I had responded earlier).
I tried playing with the converter and the V1 andI can not get it to send TV commands via the converter.
I had found a work around this and that was to buy a BV11!
Toby
Page 1 of 1 (3 items) | RSS
