BeoVision 7 mk3 DVB HD (freeview) module?
This post has 14 Replies | 2 Followers
AndrewEcosse
Posts 77
AndrewEcosse Posted: Tue, Feb 25 2014 6:52 PM
Does anybody know if I can fit a DVB HD module to a Mk3 BeoVision7? My local dealer is telling me it will not work.
Thanks, Andrew.
AndrewEcosse
Posts 77
Anybody have any ideas?
AndrewEcosse
Posts 77
Millemissen
Flensborg, Denmark
Posts 14,680
Did he tell you why it should not work?
I don't see why not.
Maybe you should try asking another dealer (who has a technician in his staff).
stefan
200 miles from Struer
Posts 2,920
stefan replied on Wed, Feb 26 2014 1:17 PM
If you are talking about BV7-40 MK III - the first Beosystem 3 based BV7 - tell your dealer, that it will work...
Stefan
AndrewEcosse
Posts 77
Ah sorry, no I'm talking about the BV7-32
stefan
Posts 2,920
stefan replied on Wed, Feb 26 2014 2:06 PM
Ok.
Sorry, no clue..
Stefan
Millemissen
Flensborg, Denmark
Posts 14,680
Well - if the 7-32 already has a scaler built in (I am not quite sure if they were born with the scaler) and you can get a HD module, that should be possible.
There are some threads about this question on the forum - and were on the archived forum.
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
I can confirm that a DVB-HD module Type 4783 can be fitted to a mark 3 & 4 BeoVision 7-32
Type 4772 is available for BeoVision 7-32 mark 5
Regards Keith....
AndrewEcosse
Posts 77
Perfect, and that unit will pick up UK Freeview HD? B&O are saying maybe not.
kai
Posts 362
kai replied on Wed, Feb 26 2014 11:10 PM
I woulda make sure you can still get the module I know some have been discontinued, even if you can still get it. Cost wise it won't be cheap for module software update and fitting you might be cheaper going external freeview box or freesat box
Keith Saunders
Posts 5,495
Kai is right that it is difficult to justify the cost of the module and its installation.
Personally, I would not add the DVB-HD module, but use a Humax STB controlled by the PUC which in my view would provide you with a better and certainly cheaper solution.
Regards Keith....
Mindphaser
Posts 100
I reup this old thread 'cause i own a BV7 - 32 MK III  too...and currently it's working fantastically with an HUMAX DVB decoder (external).
But i found this pretty rare item (BV7-32 DVB HD B/C Modul)
http://www.ebay.it/itm/272135964265?_trksid=p2055359.m1431.l2649&ssPageName=STRK%3AMEBIDX%3AIT
But, considering that is no B&O dealer in hundreds of KMs from my home...do you think guys that it would be too difficult to mount it by myself?
I own the BV 7 -32 service Manual...but it definitely seems like a work to be done by Professionals...can you confirm this?
Great and RARE kit anyway, also with HDMI ports...
Tim84
Munich
Posts 98
Tim84 replied on Wed, May 29 2019 1:46 PM
Hello guys,
let me reup this thread. I found an old BeoVision 7 at my granddads and saw that it has noted DVB on the Back. I can see a connection for a Satelite connection. Does this mean this TV is DVB-S or DVB-C ready? When I connect the TV to a DVB-C source it can't find any stations. Is there a way to upgrde the TV to DVB-C without an external receiver?
Living room: BeoVision 7 MKV + BeoLab 7-2 + 2x BeoLab 8000 + BeoLab 2 + 2x BeoLab 4000
Office / guest room: BV 7-32 MKIV / BL7-1; BeoSound Core + Turntable
Kitchen: BeoPlay M3
Bathroom: Gira Radio + BeoLab Celestial
Entrance: BeoPlay M3
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Wed, May 29 2019 8:59 PM
Beovision 7 properly covers about a 100 different variants.
Size and type number for starters ?
Page 1 of 1 (15 items) | RSS
