I want to sell my BeoSound 9000 6-CD Changer. I want to know what year it is from. The serial number starts 1400 and the type is 2662.
No the type is 2562.
It is a MK2 from the year 2000
Jonnie
Thanks Jonnie. Maybe you can help me again. My display is upside down. Do you know how to set it the right way?
Lift up the flap and remove the control panel. Flip it through 180 degrees and replace it. That should help!!
