How to adjust electronic curtains on BeoSystem 3
This post has 14 Replies | 2 Followers
DMacri
United States
Posts 881
DMacri Posted: Tue, Apr 23 2019 11:38 AM
Now that I have my Panasonic projector acting as a BeoVision on my BeoSystem 3, I noted the start up timing doesn’t match the projector startup and I’m missing much of the electronic curtains magic. I’d like to know if I can increase the speed of the startup signal to the monitor and perhaps delay the start of the electronic curtains. Does anybody know if this is possible, and if so, how to make the changes? Is it a matter of changing the selections for the BeoVision I have connected? Are there some parameters in the menu that allow these changes?
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
beojeff
USA
Posts 2,012
beojeff replied on Tue, Apr 23 2019 12:19 PM
You certainly can adjust the curtain timing. Go into the system menu (MENU, MENU, take the curser down to OPTIONS, press RED when OPTIONS is highlighted, press GO). Then select ADJUSTMENTS. And then select CINEMA TIMINGS. It takes a little trial and error to get the values exactly as you need them. If you're doing a 2-screen setup with a motorized screen coming down over your TV, you can even make the adjustment for the electronic curtains on the TV to close just before the motorized screen reaches the TV screen. The proper timing settings make everything look very smooth indeed.
I also use these settings to send out a trigger for a Lintronic code-converter to send out appropriate signals to adjust the lights when entering/leaving the CINEMA mode.
I don't understand what the EXTRA BLANKING settings are for and would welcome any understanding of that setting.
beojeff
USA
Posts 2,012
beojeff replied on Tue, Apr 23 2019 12:22 PM
P.S. Even though you're not using a CINEMA setup, you should still be able to adjust the timings for the primary display.
DMacri
United States
Posts 881
DMacri replied on Tue, Apr 23 2019 12:26 PM
beojeff:
Thanks, that’s what I was looking for. As you mention, I’m using the projector as the main and only display, so I thought the cinema settings would not work for me. I’ll try it tonight.
Dom
beojeff
USA
Posts 2,012
beojeff replied on Tue, Apr 23 2019 12:45 PM
DMacri:
beojeff:
I'm pretty sure that you can still adjust the settings for your primary display this way. I remember noticing that the timing changed for my TV startup & electronic screens when I made changes to these delays. Good luck!
DMacri
United States
Posts 881
DMacri replied on Fri, Apr 26 2019 12:15 PM
I tried changing the first group of Cinema settings- start up - but I didn’t notice any changes. Now I’m adjusting the closing settings. I’ll test again tonight since I don’t want to stress the projector with too many rapid power cycles.
Does anyone know if there is any difference between the start up routines for the various BeoVision selections in the list? I need one that supports 720p or 1080p, but has a delay before activating the electronic curtains, or sends the power on command a little sooner.
Right now when I press the tv button on the Beo4 the BeoSystem starts and maybe 3-5 seconds later the projector is turned on. By the time the projector bulb is bright enough, the curtains have already opened. Closing the curtains of course is no issue.
Dom
DMacri
United States
Posts 881
DMacri replied on Sat, Apr 27 2019 8:57 PM
beojeff:
It doesn’t seem to work like that. I tried changing the settings, but it didn’t seem to have any affect on the monitor electronic curtains.Sad
Dom
beojeff
USA
Posts 2,012
beojeff replied on Sun, Apr 28 2019 8:41 PM
I found where I had written down notes about the settings for the BeoSystem 3. (It's been awhile since I've upgraded from BeoSystem 3 to BeoSystem 4). My notes show that the "curtain delay" setting adjusts the delay before the TV (in your case projector) turns on. Maybe this might help. I had mine set to 10 seconds. I know that this cause a noticeable delay in the startup time.
DMacri
United States
Posts 881
DMacri replied on Sun, Apr 28 2019 9:01 PM
beojeff:
Thank you for digging this up. I think my problem is a little different. I need to decrease the turn on time for the projector and then increase the time before the electronic curtains active. That will give the projector bulb enough time to get to enough brightness to actually see the curtains in action.
Dom
riverstyx
SouthWest UK
Posts 938
Maybe the attached document will help?
DMacri
United States
Posts 881
DMacri replied on Tue, Apr 30 2019 11:20 AM
Yes, similar to this but for the timings for the Beovisions. In my setup, I am using the Panasonic Projector as the "Beovision" and not using Format 0. It works so far because the projector command set from the monitor output is the same as the Panasonic plasma screens B&O used for their Beovisions. I was hoping there might be some documentation showing the timing differences, if any, between the different BV models in my menu settings. I need a selection that has a default resolution of at least 720p or 1080p because my projector can't handle some of the others. Then I need it to have a shorter turn-on command, and longer electronic curtains start command to allow the projector bulb to warm up. There are selections from early BV4s through the BV12 on my list since this is late model BS3 wit HDMI outputs.
Of course an alternative is to lock the BS into Format 0 mode so I can adjust the timing as needed, but then I also need the BS3 to send the Panasonic RS232 startup commands to my projector. I don't know if that's possible. Any other ideas? Is there a difference between startup timings for the various BVs in the BS3?
Dom
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Tue, Apr 30 2019 12:01 PM
The document seems to indicate there are cinema off timings as well as cinema on timings. I'm not sure whether the cinema off timings are honoured during startup from standby, or only when you switch back out of format 0 mode but it would be worth trying if you haven't already.
Martin.
DMacri
United States
Posts 881
DMacri replied on Tue, Apr 30 2019 12:22 PM
When looking at cinema timings on my BV9 I don't seem to have curtain timers, just stand done in cinema on and stand turn delay in cinema off instead of curtain delay.
Am I missing something obvious?
Adrian
Dom
tc
Posts 6
tc replied on Tue, Apr 30 2019 10:50 PM
Adrian
DMacri
United States
Posts 881
DMacri replied on Tue, May 21 2019 1:14 AM
I found the solution! Press menu twice, navigate to options and press Red and then Go. Navigate to Picture Adjustments and change Screen On Time-out. For my Panasonic projector 30 seconds was just about perfect. Now I have visible electronic curtains.
Dom
Page 1 of 1 (15 items) | RSS
