In the process of buying a pre-owned BeoSound 9000 CD changer. Serial Nos 14758408.
Could someone tell me if this is MK1, 2 or Mk3 plsssssssssssssssssssss.
It's easier to tell from the type number found on the same label.
252x is Mk1
256x is Mk2
257x is Mk3
x depends on region
Regards Graham
That serial number is type 2562 which makes the BeoSound 9000 in question a mark2.
Opman
