Dear BeoWorlders,
I am for the moment building a new house and would like to hear your ideas on how to use my BeoStuff in the best way. Use is radio for kitchen, some play of music for listening and now and then TV and movie.
The plan for the house is shown below built with the living room as a "tunnel" from the partly sunny west side (top) to the view to the east (bottom). The profile of the tunnel (and the rest of the house) is shown as well in the next post. At the same floor there is the kitchen, TV-room, main bedroom and a bathroom. Red dots mark where there is connection to the technical room prepared for CAT7.
Currently in stock (but proposals for reasonable extension are welcome):
Thank you
The profile cut through the livingroom, which is on 1st floor.
BeoNut since '75
Thanks elephant.
The Avant is placed in the TV room ("TV-stue") where a flat screen is indicated (It´s real flat, isn´t it?) followed by a pair of BL6000.
For the kitchen ("Kjøkken") a Bl3500 is recently brought home. I have also bought 100 m ML cable...
For the living room ("Stue") I have not yet decided what to do (only that it will be without a TV). From the picture below you se the Overture with the BL2500 connected on the bench. At the moment the BL4000 are on visit as well for testing. As you can see from the drawings the room is 40 m2 and having a ceiling up to 3.5 m. The architect would like to keep the bench as clean as possible and not have any obstacles in front of the windows. Do you have any proposals for speakers and placement?
Regards
I would place the two BL4000s above the windows, one in each corner. Do not ono with color but I guess they are silver so then I would buy white frets.
If you get a Beolink Active (for around 1000 DKK) you can place the Beosound in another room.
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
Thanks Rivenflush, I think that is a realistic solution.
I have, however, been playing with the idea to integrate two BeoLab 15s above the windows and and BeoLab 16 in the wall behind the sofa. Any thoughts about how that will sound?
What a nice collection.
Amazing how well the (old) design blend into conteporary interior design.
Well done!
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
for me personally older design is much nicer than a recent.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
That's where you realize that B&O looks always better on catalogs, where nothing is connected
In real life, it's either a lot of wall work or thick and ugly wires or wires tunnels…
Nevertheless, the view from your main room is awesome!
leosgonewild:Så fint du har fått det 😀 Men hva med en 7.4 i mannegrotta?
