Hi there,
Would appreciate some help please i have just purchased a white complete beomaster 2000 type 2801
It works fine and produces sound on both channels, the main radio dial lamp is out and from reading previous posts this will also make the mains power indicator not light also can anyone confirm what bulb i need or is there a kit available? Im planning to change the electrolytic capasitors are there any other things that should also be changed.
Many Thanks in advance.
Kind Regards,
Lewis
