I posted this thread a while back, should answer everything you need to know on getting the best out of your Beovision 8.
You're in the wrong menu from memory.
https://archivedforum2.beoworld.org/forums/t/34715.aspx
Thank you. I just have to choose the right service menu. MENU - then highlight OPTIONS - then press the RED button - then press GO. Under picture adjustments turn off FILM MODE. :)
I have to say, I thought the image was pretty poor out of the box on the Beovision 8, same with many ofo really is worth having a play, just right down or take pics of the settings before you change anything so you can go back if you mess anything up.
I have an LG OLED and the Sony XE9005 currently, and because I watch Sky News all day I need to think about moving the OLED on. Sky use yellow ticker tape and yellow is killer for OLED, it wears the pixels quicker. It left some retention, which is almost gone now, however, I can't use it for Sky News, and as that is what I watch most of the day it needs to go. I liked the calibrated Beo 8 image so much I am thinking of picking up a 10-46 or 11-46.
