Tape deck recording with a beovision 5
Stu
Canada
Posts 3
Stu Posted: Thu, Jul 25 2019 2:47 PM
I thought why not try recording my Apple Music streams to cassette (for use in my classic cars). I don’t seem to be getting an audio signal from the REC OUT connection on the beovision 5.
Procedure:
Apple TV connected to TV (STB)
tape deck connected to V TAPE and REC OUT
beo4 press TV then RECORD twice... no signal.
This should work, no?
also tried Record Lock to STB. No luck.
Any help is appreciated
DMacri
United States
Posts 881
DMacri replied on Thu, Jul 25 2019 3:20 PM
Hi Stu,
What connections are you using from the ATV to the BV5? I think you would need analog inputs in order to get analog outputs, right?
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Stu
Canada
Posts 3
Stu replied on Fri, Jul 26 2019 3:56 PM
I’m using an HDMI converter with optical audio out. I don’t think it should matter as the signal should be analog by the time it gets to the REC OUT. It is described as a “pre out” in the manual.
DMacri
United States
Posts 881
DMacri replied on Fri, Jul 26 2019 4:58 PM
I agree, but I know sometimes the manual states you need to make both analog and digital connections for everything to work. I thought that might be part of the issue. Do you have a way to get an analog signal in, even only as a test of the process?
Dom
Stu
Canada
Posts 3
Stu replied on Fri, Jul 26 2019 6:05 PM
You were right! I used the analog out from the HDMI converter. Worked right away. Thanks!
Page 1 of 1 (5 items) | RSS
