Hello everyone,
I joined the ranks of Bang & Olufsen ownership recently. I am the proud owner of a Beomaster 5000, Beocord 5000 and a Beogram TX2.
I noticed that some of the inputs on the Beomaster use a DIN connector. Would this input work well with balanced XLR outputs? I am in search of a CD player and trying to find what options I have. Also, would the S45 2 speakers pair well with this setup?
Thank you in advance,
Bill
Hello Bill,
Welcome to Beoworld! Your B&O products use unbalanced connections (RCA/phono and DIN) so there is no advantage in using sources with balanced XLR outputs with your B&O system. It is possible to connect XLR but care is needed to match the signal levels so that you don't lose sound quality.
Please let me know which products you wish to add and I will be happy to help you to find the best solution.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
