Connect Beolab 17 with Sonos
This post has 7 Replies | 2 Followers
JawerDK
Posts 3
JawerDK Posted: Fri, Aug 9 2019 9:25 AM
Wondering if there are any way to include my exsiting Beolab 17 speakers into Sonos Airplay 2 system?
Br
Carsten
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Carsten,
Welcome to Beoworld!  Yes, you can easily add the Beolab 17 speakers to your Sonos network, you just need a Sonos Connect to link to the speakers.
Here is the cable you need to connect a pair of Beolab 17 speakers to a Sonos ZP80/90/100 or Sonos Connect:-
https://soundsheavenly.com/line-in-connection/av-processor-pre-amp-sonos-to-beolab-rca-line-in
You only need one cable for each pair of speakers.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
BeoMatthew
Posts 46
I noticed you specified AirPlay 2 - The Sonos Connect doesn't have AirPlay 2. This is a feature that's very slowly making its way into the Sonos lineup and it won't be updating to existing hardware like the Connect. If you want a pair of BeoLab 17s to be available as an AirPlay 2 streaming target, your best bet today is to go with a BeoSound Core or a BeoSound Essence MKII if your local dealer has one laying around. Both are AirPlay 2 compatible and frankly not many "room kits' have entered the AirPlay 2 market. Most entrants are stand-alone speakers, AV receivers, or TVs.
BeoMatthew
Posts 46
Posts 2,165
Hi BeoMatthew,
Good point, however I personally wouldn't worry about Airplay 2 as the main benefit of this is multi-room streaming, which Sonos can do anyway via its own protocol.  Beosound Core or Essence are great if you want to build a new B&O-based wireless network, but Sonos Connect should be fine for multi-room streaming via an existing Sonos network.
Steve.
JawerDK
Posts 3
JawerDK replied on Sun, Aug 11 2019 8:42 AM
Thank you for your reply. It seems like BeoSound Essenes MKII is what I’m looking for. Is not cheap but I guess nothing is when it comes to B&O šŸ˜€
JawerDK
Posts 3
JawerDK replied on Sun, Aug 11 2019 8:43 AM
PaulGiles
Posts 218
PaulGiles replied on Sun, Aug 11 2019 7:32 PM
JawerDK:
Thank you for your reply. It seems like BeoSound Essenes MKII is what Iā€™m looking for. Is not cheap but I guess nothing is when it comes to B&O šŸ˜€
Essence works very well and you can easily wall mount the best wireless remote.
Page 1 of 1 (8 items) | RSS
