Hey guys,
I have decided to change the belt on my Beogram 1200. Have take the turning plate easily out but am having reattaching the new belt right on. It keeps slipping off. Any tips and tricks how to attach it easy?
Are you sure, it's a Beogram 1200 - not a 1202/1203 or..?Are you sure, the new belt is correct for your Beogram?
100 % sure...
Could you provide a photo or two of how you fit the belt?
