Hi
There was an issue with Tune in a couple of weeks ago when they had a global loss of service.
When service resumed we had to remove all favourites and save again. It has worked fine since then.
Opman
Same problems here with Tune-In on all products.
Razlaw:No problems here (the US). Tune in on Core with BR1 working normally. However, BeoTool shows not configured and B and O app says not logged in.
mbolo01:There is no issue playing radios via TuneIn but if you have favorites, and have not disconnected from TuneIn yet, the radio behind the tile is not the one expected. BS Moment, BS Core, BS Ouverture, Beogram 4002, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
Razlaw:My favorites are working fine. Proper favorites are there. Can select both with the app and the BR1.
mbolo01:Lucky you are! At least an indication that it could be geographically related. BS Moment, BS Core, BS Ouverture, Beogram 4002, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
Back to normal today, login to TuneIn from B&O products/App works, favorites are back and operational. Surely a TuneIn maintenance over the weekend ...
