Can't Register Beocom 6000 to base
This post has 5 Replies | 0 Followers
matador43
Posts 1,373
matador43 Posted: Fri, Jun 22 2018 12:12 PM
Hi Alls,
I found bought a set of Beocom 6000 at a fair price. The set include:
-1 silver pyramid base.
-1 black charging station.
-3 handsets MK1.
-2 spares handset keyboards (the light gray part).
And the Guy was kind to give me as a gift a B&O Bottle Opener !
My goal is to fit inside a bluetooth handset to pick the calls from my cellphone (dont ask me why :-))
But prior to this i wanted to try the beocom.
The main base + handset work fine. I managed to send and receive some calls with it.
One handset seems to be stuck/frozen.
The third looks fine but won't register to the base. I've tried resetting both (•70009, unplug from mains…) with no luck. From what i get from research on the forum, there's an RF chip which happen to be quite weak. Could this be the reason why he dont find the base ?
And a side question… On the three HS, the volume control for the Ouverture works fine. Could someone telle me how it works ? Dont seems to be IR. Find it quite magical!
Thank you for you answers!
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Jun 22 2018 12:29 PM
With the stuck/frozen one it could be worth trying a working battery from one of the others.
The rf chip fault is very common and would be the reason why a particular handset does not find the base.
And the volume control is IR - via the two small dark circular bits at the top of the handset.
matador43
Posts 1,373
matador43 replied on Fri, Jun 22 2018 1:09 PM
Thank you Guy for that prompt answer.
I've try to swap batteries. It didn't help at all.
Then i must have 2 dead RF handset. That will be easier to do my little dirty bluetooth trick on a dead one.
Thank you also for solving that volume mystery!
Cheers.
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Jun 22 2018 1:31 PM
I'll be interested to hear about your Bluetooth handset modification - I have a few dead BC6000s in a box somewhere!
matador43
Posts 1,373
matador43 replied on Fri, Jun 22 2018 3:59 PM
Good to know. I'll start thread as soon as i have all the needed parts :-)
brunetto77
Posts 35
Thanks Guy. I had the same issue with two handsets, one working while the other temperamental. I swapped batteries and the second handset now works. I'll order a new battery online. I had found this brand FDK online and it's the one working.
I've also swapped the battery covers to make these two more interesting 😊
Bruno
Page 1 of 1 (6 items) | RSS
