Beovision 8-40 - what are the possibilities for wall mount?
Master123456789
Posts 237
Master123456789 Posted: Sun, Aug 20 2017 11:09 AM
Dear forum
What are the possibilities for wall mount for the Beovision 8-40? Are there only the close wall mount?
The one for the 32/26 inch: https://i.ebayimg.com/images/g/6noAAOSwmgJY3YyB/s-l960.jpg - is this also made for the 40 inch?
Thank you
Peter the Biker
Eastwestfalia
Posts 944
Maybe stbbrackets has the solution ...
http://www.stbbrackets.co.uk/en-GB/products/beovision-8-40
Peter the biker
Master123456789
Posts 237
Thank you for the feedback :) :)
But aren't there any original B&O? - and also 500 punds is a bit to much!
Zwets
Posts 111
Zwets replied on Mon, Aug 21 2017 9:15 AM
BV-8-40 has only a flat wall mount bracket. It is original B&O and did not cost 500 GBP.
Ralf
Hamburg Germany
Posts 189
Ralf replied on Mon, Aug 21 2017 9:36 AM
the original B&O is out of production now.
St brackets has one still avaiable. But it is a flat wallmount (about 200 Euros)
The smaller original B&O for 8-26 and 8-32 won't fit. It is possible to expand the 8-32 with alloy profiles, if you are able to do it yourself.
(Cutting alloy and thread cutting)
The smaller 8-26 then fits the 8-32 and the 8-32 fits the 8-40 without any conceren of load bearing.
Ralf
Master123456789
Posts 237
Is this picture a BV 8-40 on a wall mount for a 32? And where have you got it from? :)
TATYN
Posts 7
TATYN replied on Thu, Oct 17 2019 6:31 PM
J'ai installé le  Beovision 8 40 avec le support mural 8 32 en ayant fixer dessus un support mural 8 40.
Page 1 of 1 (7 items) | RSS
