Beomaster / take off the top aluminium cover to change it ?
Moonica
Posts 2
Moonica Posted: Wed, Oct 16 2019 2:18 PM
Hi B&O lovers ;-)
I love so much B&O, that I have 2 Beomaster 1900. One works fine, the other doesn't, but the one that works has a deep scratch on the brushed aluminium part of the panel that opens and closes on the top. So I would like to exchange these panels between both machines.
Does anybody know if it is complicated or not to exchange those panels.. ? As far as I have looked, it seems well intertwined...
Thanks a lot ;-)
Moonica
Posts 2
Moonica replied on Fri, Nov 8 2019 10:11 PM
Well indeed the top is in one piece, so there are 2 screws on each left/right side of the command table under the aluminium cover. Then, on the vertical back side of the machine, there are 4 screws. Once all these are unscrewed, all the top is released.
Page 1 of 1 (2 items) | RSS
