Hi
I have a RIAA box between my Beogram 2202 and my Beomaster 2300. I am wondering if the type and quality of the RIAA box will impact the sound coming from the Beogram? Thus, is it important to have a high quality RIAA for the best sound?
Thank you sincerely for your reply :)
Edit:
I wrote wrong above, it should be Beocenter 2300 instead of Beomaster 2300
EMBO: Hi I have a RIAA box between my Beogram 2202 and my Beomaster 2300. I am wondering if the type and quality of the RIAA box will impact the sound coming from the Beogram? Thus, is it important to have a high quality RIAA for the best sound? Thank you sincerely for your reply :)
RIAAs come in all shapes and qualities, but why not just plug the Beogram in to the Beomasters PHONO input?Beomaster 2300 has a fairly good built-in RIAA for that same purpose.
Thank you for reply and RIAA clarification :) I wrote wrongly above, it should be Beocenter 2300 and not Beomaster 2300.
