I have owned this for about 25 years and I have lost the manual. I had cable but switched to satellite and need to hook up tv through the s-vid cable. I cannot even remember how to access the menu! Pushing the menu button in itself does nothing. I have downloaded a manual but the remote shown on the manuals I downloaded show a satellite button where my menu button is located. If I remember it was a multi-step process… I have forgotten even how to set the time… Help
Jeff
OK
Shift ABC gets me to the menu... I got that figured out! Now I am setting up conections and I want to use a s-video conection... What is that setup code? I do also have a video security camera hooked up to cable "A"
Where are you? And which type is the MX5000 - the US model is completely different to the UK model so we don't want to confuse things!!
Peter
