Are there any versions of the Beo4 which do not have link volume control? i.e like the Beolink 1000.
I am not sure that I understand the question, but as far as I am aware you have been able to add the LINK function to the LIST button on all Beo4 models, except perhaps hotel versions.
And BL1000 has always had the LINK button too!
(And the LINK command does not actually send an IR command, it works a bit like the SHIFT button by changing the IR command that follows. Thus the IR (Beo4 or BL1000) command that follows LINK will only control LINK products, or products that have been set up with the relevant L.OPT setting.)
Further to my last, I am guessing that the question refers to the same problem that you posted about several years ago. Clearly it continues to annoy you!
I have reverted to your earlier thread to propose a solution:
https://archivedforum2.beoworld.org/forums/p/12713/110696.aspx#110696
