I think it would just be a rubber spacer to protect glass and screen. Just become loose... might be easier for a B&O tech to do... i don't think you can get in there otherwise
Did you try with a vacuum cleaner?
Maybe it does not stick that much?
Avant screens often have dust on the inside so I take them off and clean them now. It's about an hour and a half to take it off, clean it, and put back on.
Lots and Lots and Lots and Lots of screws.
Lee
HI Lee - my Avant has so much dust behind its screen, I'd love to clean it myself if possible. Can you share some details on how you went about this?
I got the Service Manual and gritted my teeth!! I also have the service feet for the Avant, which really help...
