Beosound Essence and Bs3200 and BL3500
This post has 5 Replies | 0 Followers
BenSA
Durban, South Africa
Posts 1,404
BenSA Posted: Wed, Oct 30 2019 9:31 AM
Hi
I have bought a Beosound Essence 1st Generation for the lounge. Currently I have a beosound 3200 with BL8000's and BL3500 via masterlink in the bar next to the lounge. Will I be able to connect the BS3200 and BL3500 to the Essence. Currently I can have the BS3200 playing or just the BL3500 playing or both together.
Thanks!
Ben
Millemissen
Flensborg, Denmark
Posts 14,680
The Essence will have to be connected to the AUX-in of the BS3200....which will work fine.
However - depending on the SW version of your BL3500 - this may not be able to start up with the AUX command directly.
So the answer is yes and (if your 3500 is not from a newer gen) no.
It is possible to upgrade the 3500 with a later SW chip.
Millemissen
Flensborg, Denmark
Posts 14,680
As for updating the 3500 see this thread:
https://archivedforum2.beoworld.org/forums/t/20499.aspx
The easiest way to find out, if it works with the 3500, is to connect something to the 3200 (e.g. a mobile phone/headphone output) to the AUX-in and test if you get sound through the 3500.
Should you need cables for connecting the Essence to AUX-in, I am sure that Steve/SoundsHeavenly can help.
BenSA
Posts 1,404
BenSA replied on Wed, Oct 30 2019 11:30 AM
Thanks for the info MM
My BL3500 does work with the AUX command so that's not an issue thankfully.
So therefore I won't be connecting the Speakers to the Essence connection box?
Sorry I don't understand exactly how the Essence would be connected to the BS3200's AUX? There is only a line in on the Essence from what I can tell from photos...no line out? It only arrives later today.
BenSA
Posts 1,404
BenSA replied on Wed, Oct 30 2019 12:12 PM
Oh you use the PL to Aux! Got it thanks.
Millemissen
Flensborg, Denmark
Posts 14,680
Basicly you use the (PowerLink port of the) Essence in ‘line-out mode’.
Or you make sure (in the app), that the volume is set to approx 85%, leave it there and do all volume control via the BS3200 respectively the BL3500 (i.e. the Beo4).
It is then just a hide-away-box, which does it’s magic  🙂
Please note, that the Essence has a line-input.....which has autosense.
This might be handy if you have further devices that you want to listen to.
Page 1 of 1 (6 items) | RSS
