I’ve change my beosound 3200 for a Beocenter 2. The 3200 sounds so much better but when I try switch the loudness on on the BC2 it makes no difference at all. BC2 sounds muffled....same speakers....same wires. So disappointed......is there something wrong with the BC2?
Hi Ben
I was thinking of doing the same swop.... let us know if you get the problem fixed. I can’t think for a second that the BC2 has inherently inferior sound quality.
Cheers
Nigel
My Beocentre 2 sounds alright. Maybe yours has a problem? It's for sale too.
