Beovision 11 and Beosystem 3500
BenSA
Durban, South Africa
Posts 1,404
BenSA Posted: Wed, Nov 13 2019 6:22 AM
Hi
I would like to connect a Beosystem 3500 to my Beovision 11. I know how to link products via Masterlink but the 3500 doesn't have masterlink so now I am rather clueless.
If anyone can let me know how to do this.
Thanks so much
Ben
Steffen
Denmark
Posts 1,408
Steffen replied on Wed, Nov 13 2019 7:48 AM
Hi there
I guess you'll need a Beolink Converter - like this one.
https://www.beoworld.org/manuals_view.asp?pid=983
-as a Silver member you can download the manual.
Then you'll offcourse need to find a converter Wink Try ebay or other sites for used electronics - or maybe some friendly Beoworld members have one for sale.
BenSA
Posts 1,404
BenSA replied on Wed, Nov 13 2019 7:58 AM
I have 3 of those converters actually so thats good news except I still don't understand how one would set it up.
If neither the Beosystem or Beovision have a masterlink socket how would you connect everything together?
Millemissen
Flensborg, Denmark
Posts 14,680
You’ll need two (different) converters for that setup.
Here is a drawing of the physical setup - settings of the NL/MM Converter are a different subject:
BenSA
Posts 1,404
BenSA replied on Wed, Nov 13 2019 8:40 AM
Ah ok. I don't have an NL/ML converter. I shall have to look for one.
Thanks MM for the info.
Steffen
Denmark
Posts 1,408
Steffen replied on Wed, Nov 13 2019 8:41 AM
Doesn't the Beovision 11 have a Masterlink socket? (I thought so - but I "only" have a BV 10)
- then I don't know...
(edit: I can see that Millemissen has the answer) Smile
BenSA
Posts 1,404
BenSA replied on Wed, Nov 13 2019 8:48 AM
Hi Steffan
No masterlink on the BV11 unfortunately.
beojeff
USA
Posts 2,012
beojeff replied on Wed, Nov 13 2019 1:43 PM
Does anyone know if it makes a difference whether the BS3500/BS4500 is set to the TAPE 2, CD, or PHONO option? It seems that it might make a difference on how the aux port functions. I've always found the section of the BS4500 manual regarding this to be unclear.
BenSA
Posts 1,404
BenSA replied on Thu, Nov 14 2019 8:09 AM
This might be a very dumb question but I am going to ask anyway! Can a Masterlink Gateway (the black box one) be used to do the connection between the BS3500 and the BV11? I have a brand new one in a box which I never used, partially because I have no idea how to use it.
Page 1 of 1 (9 items) | RSS
