Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
B&O should have a master code they can supply. If you have WAIT because of making an error then, if like the old Avant procedure, you need to leave the TV for several hours before you can try again. And you must leave the TV connected to the mains.... if you unplug it then the WAIT sequence will start again. Graham
