Is there a way to connect an audio only input to a Beovision 9 that I can select without the screen coming on?I want to add a Sonos connect so could use either the SPDIF or the analogue connections on either of the spare A/V inputs I have (av1 and av6) however in the connections programming it looks like the only options will bring the screen on as well.
I don’t have an audio master connected via masterlink or I could have connected via the aux input there.
Am I missing something obvious Or am I stuck with having the screen on all the time I’m listening to audio?
Thanks,
Adrian.
Thanks, I’ll give that a try tomorrow
