Beovision 7-55 - Apple TV
twowheel2001
Posts 39
twowheel2001 Posted: Fri, Nov 29 2019 8:29 PM
Hello,
after fixing the majority of issues with my newly acquired TV,  there is one left.
I use my  shortly purchased 7-55 mk1 with technisat Receiver and Apple TV 3rd Gen. All controlled via Beo4.
2times already in 4 weeks, there is an issue, that After changing from DTV to Apple TV and watching YouTube, the System locks up and does not accept any command of the Beo4.  Neither on/off, nor louder or anything else. Only way to move fortwarf is, to pull the Plug and restart.
is this a Common/ known issue? Any fix?
thanks,
markus
Razlaw
Posts 4,345
Razlaw replied on Sat, Nov 30 2019 1:18 AM
I have not experienced anything like that with my BV7 and Apple TV.
Esax
Posts 323
Esax replied on Sat, Nov 30 2019 8:01 AM
I have used mine with apple tv 3, 4 and now 4k. Never had any problems. But I do not use puc.
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
twowheel2001
Posts 39
Will probably try other PUC socket next time. So far only appeared with Apple TV, not with receiver!
very odd.
thanks for your Reply anyhow!
twowheel2001
Posts 39
very odd.
xsanderr
Posts 13
xsanderr replied on Sat, Nov 30 2019 6:01 PM
Yes I was facing the same problem
i am using atv2 and restored this completely and reset newly by iTunes
Also used WiFi on the atv and is cable connected to router
Page 1 of 1 (6 items) | RSS
